What did you work on today?
Those look nice! 🔥
Please let me if you like them after you get some time with them.
What's not to like? They are 7075 aluminum and super thick. I don't jump my Asuga - I primarily run it fast on my dirt and grass backyard, so the shock towers won't get much punishment.
Installed the max6 G2 combo in my infraction to test out, so far it seems plenty good for street bashing
That thing is 🔥🔥🔥. A little Nismo love! I looked at one of those before I bought my S6, freaking tight! 👍👍
Also, my adult ADD very much appreciates the fact that the left and right sides are almost mirror images of each other and the white wheels set it all off! Nice ride Angry!
🤔🤔🤔🤔🤔hmmmm, dual motors is giving me ideas! ……..😈
Worked on my dual motor car, waiting on one last piece then I can finally test it
Can't wait to see what it can do. 😎 Please post your speeds and times here.
I'm looking at taking my rigs out, hopefully this week, to see if I can beat my truck/truggy top speed and 0-60mph personal bests.
If circumstances allow, I'm hoping to enjoy RC again. 🤞
How you make two esc react to just one controller? 🤔
I suppose you'll need more than a standard controller for that, right ?
It's pretty easy actually, any normal radio/receiver, just calibrate them individually then hook them to the receiver via a y splitter, one esc you'll need to pull the red wire out of the connector so your not putting power to the receiver off both, I pull it on the y to not alter the esc itself, just have to remember to turn the "powered" esc on first
The shims for the front upper suspension arms arrived today and I installed them. I had been utilizing a temporary fix to solve the issue of the front suspension arms not fitting properly after installing the aluminum steering deck and new suspension arm mounts, but now the issue has been fixed correctly.
so how did you fix the front arm shim issue? i haven't upgraded anything on the front arms only the tower to tower brace. i noticed the front right arm has too much play. any suggestions ?
