AnthonyJaques
Rear tower added was a kronos tower and the gpm dual stage shocks are on ebay or aliexpress watch because there are 2 version ones with aluminum rod ends ones with poly ends I recommend aluminum ends. They are the rear 135mm arrma kraton/fireteam gpm shocks. Google should bring it upAny links for the tower/shocks?
35 bucks a pair remember 2x rearsRear tower added was a kronos tower and the gpm dual stage shocks are on ebay or aliexpress watch because there are 2 version ones with aluminum rod ends ones with poly ends I recommend aluminum ends. They are the rear 135mm arrma kraton/fireteam gpm shocks. Google should bring it up
Corally has same size all the way around while arrma fronts are 115mm that is why you need 2 rearsRear tower added was a kronos tower and the gpm dual stage shocks are on ebay or aliexpress watch because there are 2 version ones with aluminum rod ends ones with poly ends I recommend aluminum ends. They are the rear 135mm arrma kraton/fireteam gpm shocks. Google should bring it up
Depends on driving style I guess I wouldn't use them for like track racing but for large air definitelyAre you happy with the shocks? I keep reading they are rather weak and "style over substance".
And they are like 8mm longer than corally so when installed they are slightly preloaded without rolling the adjustment downBouncy if your light but I've railed them 30ft in the air I love em
