Asuga Sequence wire
madasuga25
Hello corally peoples,
I'm considering removing the sequence wire to run a single plug but not sure if I can keep external capacitors or is it removed and what has to be done with the 2 smaller negative and positive wires that feed into capacitors. Or is it best left alone. Thanks all
yes you can run a single plug & keep the cap pack this vid should make sense of it all for you. Corally esc is rebranded Hobbywing.
The ESC and capacitors don't know if you're running two batteries, one battery and a jumper plug, or just one plug. If the capacitors are not directly connected to the plug then it's safe to cut the plugs off and solder a single plug on.
Thanks mate, all done.
I prefer to desolder and then resolder. No need to cut the wires or pretin, and plugs are reusable.
