Kagama Post your 0-60mph times here!! 3S,4S,6S,8S - what have you!
This can be with any rig - what have you. If you rig doesn't hit 60 - post your 0-50 times. Just because! 😎👍
I'll kick off with my 0-60mph times:
Kronos XTR, 6S
Sworkz S35 T2E, 6S
How are you measuring this ?
Angry section 8 beat me to it! 😅
Yep, the Sky RC GLONASS/GPS tracker is very good. It's small enough to mount in most rigs. I use 3M Dual Lock.
It's very accurate - I've used it in my full size car and compared it with the speedo.
My one criticism is that the battery seems to run down even when I think it's turned off. You have to charge it right up before you need it.
The app to read it works on Android or IOS and is pretty slick.
The G sensor is possibly glitchy. I note some of my quicker 0-60mph times have lower G readings than slower times, so that doesn't make sense to me.
Otherwise, it's a must have. When people ask you 'but how fast is it really?' - you're going to know! 💪👍
Well I was messing around with my Asuga at Brooklands Park and another RC guy turned up and he had a some sort of GPS device Which slotted in between the battery try and the extender bit and did a couple of runs managed to get 52mph on 6s and 37mph on 4s i was on the road tyres which are slightly smaller than the of road wheels and I am running standard pinion too.
That's fairly rapid considering the lower rollout with smaller tyres. You can get bigger slick tyres and try some 0-60mph times.
Enjoy.....😝
Baja 5B 0-40mph time
For such a big rig, this seems pretty good I reckon. The engine sounded on point too. 😎
Something that big moving that quick can be quite disconcerting. :D
Hey where's that fella that was standing on the trackway in front of everyone else? Maybe a 5B going 40mph through the air will reignite the cognitive process? 😁
Your rig should hit 60mph on 13t on 6S. 👍
Don't over gear it for 0-60 times.
Good luck!! 😎
Do you think a 15T Pinion is too much ?
I only got 52 MPH on the co rally road tires they are slightly smaller than off road tires
Maybe i should get some wheel like yours the look bad ass :giggle:
Ok - if you measure the diameter of the tyres and the number of teeth on your spur, I'll calculate your exact rollout in mm/rev, using the 15 tooth pinion. That will enable us to get the exact theoretical speed.
For 0-60 times, you don't want to gear too much over the target speed, otherwise you'll take slightly longer to get there than is necessary. 👍
The Jetkos are badass! 😅 But they're also very heavy and needed balancing properly. They certainly work though! 💪
My Sky RC GNSS Turned up today so when it finally stopped raining would be rude not to try it out. I put the off road wheels on as a bigger diameter. My 15t Pinion has not turn up yet so on standard one, for now
Could not do 0-60 as topped out at 55pm on 6S 38mph and on 4S, was still wet was disappointed with the 0-50 time !
Took off road a bit and got filthy so decided to make my own car wash with a puddle
The GNSS fit perfectly in the battery tray between battery and ECU
