Horatio
- Thread starter
- #21
The wet conditions will negatively impact your 0-60 times (or 0-50), but you should be hitting 60mph on 6s, provided your cells are healthy and your gearing is what you think it is.My Sky RC GNSS Turned up today so when it finally stopped raining would be rude not to try it out. I put the off road wheels on as a bigger diameter. My 15t Pinion has not turn up yet so on standard one, for now
Could not do 0-60 as topped out at 55pm on 6S 38mph and on 4S, was still wet was disappointed with the 0-50 time !
Took off road a bit and got filthy so decided to make my own car wash with a puddle
The GNSS fit perfectly in the battery tray between battery and ECU
13/52 should be what your V2 Kronos is on.
A set of 150mm tyres would give you a rollout of 35.62mm/rev.
From that, we can calculate the exact speed to expect on a 2050kv motor running on a good, freshly charged 6S battery - which should give us 25v.
Deduct approximately 6%, or 4mph in this instance, for real world losses unaccounted for, and you're looking at 64mph.
Assuming your batteries are giving the expected charged voltages, it might be worth checking the ESC punch settings.
Driveline and bearings for freeness. Double check mesh on pinion/spur and even the inputs onto front and rear diffs if you're feeling determined.
Your Kuron 825 2050kv has more love to give yet - so keep em' coming ....
*Ahem*... quietly gets Kronos and quickly prepares for additional speed runs.......
