Nelson.81
I hold the servo horn by hand then I turn the wheel against it by hand also and you can see & feel how much load it takes to split the servo saver set it as tight or loose as want it. So if you hit your wheel in a bump the kind of impact that would put the servo saver you want it to split & save the servo but still be tight enough so the load put on it when steering isn’t enough to split it so still have positive steering feel. It’s just getting the balance between the twoI'm very curious as to what methodology you're all using to set your server savers so that they still "save".
I clamp the front wheels in workmate bench and articulate the servo, and keep tightening right to the point just before where it looks like it's locked and then back off an 8th. Can be a laborious process, but I want maximum steering with minimum loss of "save"
