Nelson.81
I also have a question about your driveline. Im gonna start a new build soon & going to make driveline straight like yours but use if different length shafts so hopefully won’t have same issue with difficulty getting front shaft in. But looking at different length shafts I can do it with do you think total length of 85 +168=253 is the ideal setup how much float is there front/rear want would you say is perfect total length. I’ve looked at scorched shafts to see what combinations I can make up for what I want to do & one of the 249mm setups would work best for me so do you think I would get away with loosing that 4mm over the 253 mm overall length? I think if not I could maybe use an arrma centre diff gain a few mm back but all in the calculation stage atm.
