mrBigpitts
This is what 2.5k will get you in Australian dollars. Heaps of fun!
this is what 2.5k looks like in Australian dollars.
Na mate,just running 8.4v off the max 8 esc,you're not wrong about the cost of things in Australia, my 12s Kraton with the m2c chassis and vitavon gear is into me for 5.6k.£1250 uk dam sh$t ain’t cheap in Australia . Is that a separate bec for the fans?
Whats the little circuit board on top the receiver box then thought it was a separate bec?it's a led controller pcb for the lights you can see fitted to the side of the car,I can switch them with a spare channel from my dumbo transmitter, im getting old and it helps me whenever I'm driving at the local park at night.
It was part of the 20 dollar light kit i purchased from Amazon, I routed the wiring as neat as I could seems to be holding up well,would have liked to put it in receiver box as well but no room.Can get recievers with led control built in one I had was too big for corally reciever box couldn’t really close lid tight. But all wiring bugged me anyway so pulled it all out
I wish corally would redesign it I hate it lol I think it & servo mount could be better designed less screws, weight & less of a pain to feed wires into it. Gripe over have a good wkendIt was part of the 20 dollar light kit i purchased from Amazon, I routed the wiring as neat as I could seems to be holding up well,would have liked to put it in receiver box as well but no room.
Yep,total pita, ive cut a notch in the side of all my corally receiver boxes so I don't have to remove them when I change servosI wish corally would redesign it I hate it lol I think it & servo mount could be better designed less screws, weight & less of a pain to feed wires into it. Gripe over have a good wkend![]()
Lol so I've been hearing having a larger scale is more of a statement piece then anything. Mostly the reason I haven't added one...yetNa mate,just running 8.4v off the max 8 esc,you're not wrong about the cost of things in Australia, my 12s Kraton with the m2c chassis and vitavon gear is into me for 5.6k.
All that cash and the biggest enjoyment I'm having at present is driving is my stock kagama 4 with 13mm hub extensions.
Why thank you SIR!kag4 is great once you ditch the factory shock oils! Get a motor fan if you're gonna run 17T off-road, also worth upgrading the rear driveshafts to offset dogbones if it doesn't come with them.
I know and it's cheaper! So crazy! Lol watch TC fix thatYes siree, punisher body is far better looking
Very neat,never thought about doing it that way,I don't see you having any problems with that servo they are quality units.Fingers crossed I don’t do a servo but put connectors on outside receiver box in case fans fail for quick swap.
Tough as nails and gives me a lot less grief than my kag 6 cars in regards to breaking things,my son always takes it and says he would have bought one rather than his kag 6 in hindsight.Lol so I've been hearing having a larger scale is more of a statement piece then anything. Mostly the reason I haven't added one...yet. I was at the some what local (hour drive) hobby shop yesterday and the stack of TC vehicles looked so good I contemplated bringing the 7 or so rtr and rollers home hahaha but I'd be dead once I put the truck in park at home lol.
Whats your thoughts on the Kag4?
