Horatio
The spring you need is:Hia, I’m trying to find the post, or the actual place I can get an upgraded servo saver spring.
Is there a certain spring, gap to measure when fitting an upgraded one?
LC 085J 0 M
from Leespring.
The specs for the spring are:
| Part Number | Outside Diameter (mm) | Hole Diameter (mm) | Rod Diameter (mm) | Free Length (mm) | Rate (N/mm) | Solid Height (mm) | Wire Diameter (mm) | Material | |
| LC 085J 0 M | 18.29 | 19.05 | 13.44 | 19.05 | 24.343 | 9.07 | 2.16 | MW |
