Chuzz
I’ve received my DumboRc DDF350 this week, with X6FG receivers, 1 in each of my Muraco and Radix.
Setting the steering end points is easy and so much better than the stock transmitter.
There's way more on this transmiter than I'll ever need, I think 10 channels! but I only need steering and throttle really.
BUT (and can anyone help here?) I have programmed two models on my transmitter; 1) RADIX and 2) MURACO. I set the end points and set up the RADIX as the receiver/transmitter that comes are already bound. I bound the other I've put in the Muraco. Then tested by switching the transmitter model memory to the RADIX… and it still controlled the MURACO. Shouldn't the model memory only operate the model that is bound? Or am I binding incorrectly? The instructions for the transmitter are very basic.
I don’t want end points getting mixed up depending which car I use.
And how do you get the gyro to perform? How can’t be tested without driving? I’ve found the gyro on the transmitter but turning it on doesn’t seem to do anything. Do the corally cars esc’s recognise the receiver/transmitter has a gyro?
Any help or a manual download would be awesome
