Atomic Skull
I'd be all over that, if I'm going to have to disassemble it and put it back together to my standard I may as well just start with a box of parts.
My Shiroi had no shims on the center diff (over 0.5mm of sideways play) and the axles were over shimmed, they've apparently started putting two shims under the outer wheel bearings retaher that one to eliminate out of the box play in the axles at the cost of some axle bearings being overloaded and brinneled. What they should be doing is one bearing shim per hub (like they used to do) and then provide a pack of axle shims on .2 .1 and .05 and tell people they need to shim the axles because every hub or steering block needs different shimming due to tolerance stacking. I understand that this is too time consuming to do at the factory but over shimming everything is not the answer.I wish every RTR was also available in kit form. After a few weeks of owning my kagama4 I'd had a few shall we say not quite enough loctite issues, I took it apart and rebuilt anyway
Looks weird, it’s like they just took a truggy kit and put a short chassis and the wrong wheelsNot released yet but this has caught my eye If interested in a kit.
https://answer-rc.com/sworkz-off-ro...-truck-brushless-power-kit-4710345174767.html
You're right but reading the description it doesn't even come with wheels or tyres which might explain their odd choiceLooks weird, it’s like they just took a truggy kit and put a short chassis and the wrong wheels![]()
lol chassis length is in between buggy & a truggy so similar to an outcast or a mt410 so what wheels tires put on it could make it a sct, truggy , stunt truck whatever you want. I was just looking at the bbs shocks it comes with to put on a build they £150 on there own throw in the 7075 chassis & shock towers I think it’s a nice little package.Looks weird, it’s like they just took a truggy kit and put a short chassis and the wrong wheels![]()
