shortround9191
The mount that goes on your motor the fan connects to??
I didn’t really abuse it, especially since it’s brand new, I don’t really abuse any of my RC’s I just drive them fairly hard.
Corally composite plastic choice on earlier Kronos was too rigid (resulting in more positive response at expense of durability in crash), but later rigs have more durable properties.I think the plastic that Corally are using isn't up to the quality and toughness that Traxxas make their HD suspension arms out of.
I’ve been watching lots of videos mostly bashing, your correct Traxxas and another brand ( unless you buy the crazy expensive one has tons of diff issues ). I’ve seen so many talk about how well the TC cars are ( recent models ) even the standard Kagama 6s when compared to the Arrma. I actually watched one yesterday comparing them and to build the Kraton to the Kagama was a $300 difference. Yes tons more aftermarket for other brands hopefully more will come to TC sooner than laterI think crashing/bashing cars can always result in damage. Sometimes the damage seems worse than it 'should' because: physics. Other times: horrendous crash = no damage.
Traxass on the other hand are hardly a shining beacon of light when it comes to quality. Unless of course you define quality by how many ££$$ you spend on a rig made entirely of recycled milk crates.
Having said that, on X Maxx, the first thing bashers do with it is fix the entire drive line with M2C stuff and CNC gears, because the monkey metal Traxass use is crap. And that's me being kind. I could say more, but won't.
Quality = Xray, Sworkz, Scorched Parts, M2C, Kyosho etc.
Personally I feel for what I spent on my XTR, the quality per £ spent was greater 100% better than Traxass.
I love the Kraton EXB as well.I’ve been watching lots of videos mostly bashing, your correct Traxxas and another brand ( unless you buy the crazy expensive one has tons of diff issues ). I’ve seen so many talk about how well the TC cars are ( recent models ) even the standard Kagama 6s when compared to the Arrma. I actually watched one yesterday comparing them and to build the Kraton to the Kagama was a $300 difference. Yes tons more aftermarket for other brands hopefully more will come to TC sooner than later
I don't fully agree with you on Traxxas. Many of the plastic parts they use are very durable, suspension arms and chassis' in particular are very strong on Traxxas cars, in general.I think crashing/bashing cars can always result in damage. Sometimes the damage seems worse than it 'should' because: physics. Other times: horrendous crash = no damage.
And thankfully, you don't have to.I don't fully agree with you on Traxxas. Many of the plastic parts they use are very durable, suspension arms and chassis' in particular are very strong on Traxxas cars, in general.
I haven't owned an X-Maxx, but if my experience with the 1/10 4x4 cars goes, the spur gear would probably be fine, if you made sure the gear mesh was locked in place securely.
On the 4x4 models, the plastic spur gear strips because the motor mount design is a weakness and it allows the mesh to loosen, the problem here is not the spur gear itself.
I do agree that those brands mentioned provide actual quality, I own a Tekno EB48 2.0 which is fantastic and uses top notch materials throughout.
Been the same on all so far start hearing a strange noise first time thought it was a fluke this time figured more to it and TC doesn’t have anything but stock gearing or lower in inventory
This sounds like the motor screws that go through the motor mount and into the motor front cap have come loose and allowed your gear mesh between the spur and pinion gears to come loose, which would damage the gears.
Those screws need to be really tight and have red thread lock so they are secure and can handle heat from the motor.
I did similar with a new 7075 chassis I was lucky that I was able to hammer out the damage & still use the chassis.Update on the Syncro.
Had a good run yesterday, but not without some damage!
Unfortunately hit a concrete edge when attempting to cross from the road onto the grass land, smacked the chassis right into the concrete as it was just the right height; it stopped the buggy dead, from about 40+ mph, so was a big impact!
Bent the chassis, ripped the threads on the front bulkhead and damaged the front left shock absorber, the seals fell out and oil splattered everywhere!
Aside from that, I fitted a high spec SRT BH9027 servo which transformed the handling and steering response. The steering is now super quick and it turns confidently every time, maintaining a tight turning circle. Definitely a worthwhile upgrade.
Well I'm glad the servo survivedUpdate on the Syncro.
Yes please!You know the way you can’t use bad words on this forum can we have traxxas added to that list of words![]()
The asuga was too fragile for you? What were you doing crashing it into stumps? It's a buggy not a monster truck if you drive it like one it will break.Just got my new Syncro 4 recently.
1st run, broke a lower suspension arm, bent the steering rack bar and also bent both front driveshafts.
This is Corally's second chance with me, I owned an Asuga a bit ago which I really enjoyed driving, but it wasn't durable or reliable enough unfortunately.
Keen to hear others experiences on the Syncro and how well it holds up long term.
I clipped a curb with a front wheel at 20mph and the result was 100% my fault, it bent steel and 7075 aluminum it's unrealistic to expect it to not also split the upper arm. If anything I'd prefer that to more serious damage because that was easily fixed. if it had damaged the lower arm or the hinge pins disassembly and repair would have been much more painful. Going forward no more aluminum upgrade parts they're not worth it. EDIT: I suppose I should mention the power system in this thing though a 1/6 scale ESC and motor may have had something to do with it
That said the ADU Racing nylon "cowcatcher" bumper is really great and will help absorb impacts and save the suspension arms in frond end collisions.
Are the front wheels meant to be pointing outwards at the front like that, mine looks similar, not sure if I've bent something or they are meant to look like this? All the plastic steering arms and suspension arms look okay but I know they are attached to a metal steering arm length thing on the inside. Thanks in advance I'm a newbie and I'm not sure if I should be posting this hereCan upgrade it this one has a lot of spark parts fitted to it, adu hinge pin holders, shock towers & t2t brace, spark arms, side guards & bodyshell
A little bit of Toe out 1-2° is healthy. I'm guessing your Ackerman plate is a little bit bent.Are the front wheels meant to be pointing outwards at the front like that, mine looks similar, not sure if I've bent something or they are meant to look like this? All the plastic steering arms and suspension arms look okay but I know they are attached to a metal steering arm length thing on the inside. Thanks in advance I'm a newbie and I'm not sure if I should be posting this here View attachment 12001View attachment 12002
