bckyrdbshr
What's your preferred upgrade material and why one over the other?
Titanium?What's your preferred upgrade material and why one over the other?
The only sensible solution is both. Preferably at the same time!Aluminum here. I like to make my own skid plates and body mounts from aluminum and Kydex plastic. I've been tempted to try CF but, I do use most of my rc's year round(snow) so.![]()
Indeed!! Nice Baja!
Thank you. The Baja 5B is a great driver's car too.Indeed!! Nice Baja!![]()
I see HPI has re-released the 5B in kit form. Gas or electric. Gotta be a "drivers car" on 8s!?Thank you. The Baja 5B is a great driver's car too.
I was going to take a picture of the under chassis for another thread, but then I changed my mind....![]()
Metal every time. Carbon may look nice but you can’t bend carbon back into shape if you happen to bend it. 7075 T6 will bend and straighten in a vice. Carbon will just snap. If you want it made out of a fancy material, use Titanium. Prices are getting reasonable. I prefer the black look of 7075.Definitely metal, so either aluminum or titanium, choice of which (for me) is driven by price.
I tend to steer clear of carbon fibre, as greases/oils, sunlight, water etc can cause the resin to break down. And of course a 'lack of talent' moment can cause delamination, loose fibres into the skin etc. Metal can be smoothed with a file, carbon not so much.
Carbon fibre, depending on the lay-up, can be far more flexible than 'metal' when required. We also need to be much more specific when referring to 'metal'.Metal every time. Carbon may look nice but you can’t bend carbon back into shape if you happen to bend it. 7075 T6 will bend and straighten in a vice. Carbon will just snap. If you want it made out of a fancy material, use Titanium. Prices are getting reasonable. I prefer the black look of 7075.
| Stiffness against weight (Specific Modulus) Unit: 10 6 m2s-2 | 26 | 25 | 56 | 83 | 120 | |||||||||||||||
| Resistance to damage (Specific Strength) Unit kN·m/kg | 214 | 254 | 392 | 211 | 126 |
Alloy parts are just too shiny to say no to.Really then it’s down to personal preference.
That’s great shaving a couple of grams off here and there. Let’s say 25 grams saved changing what you can to carbon. The next improvement that needs to come is lighter better batteries. My 6000mah hard case lipo weighs a great deal. A battery half the weight but more efficient would be a true breakthrough if they were available to the everyday RCer. I have 2 3S lipos that are quite light but only 3000mah combined. Less weight and less time having fun.
As for the Carbon, ok I am convinced but having just spent £350 on the 7075 stuff it will be a while before I swap it all. Hopefully by then more Corally carbon parts will be available in the UK. Mainly it’s just Corally themselves selling them. In time UK suppliers will also get on board.
It's for a tower brace for the trucksin relation to the ongoing debate about the pros and cons of 7075 v Carbon. On the front Chassis brace for the Python and others made from 7075 there is a post about half way along that is threaded. What is this for
