Spark Oh, crap!!!
SirCrashALot
Earlier this year i bought a brand new green Spark roller.
I had it sitting on the shelf untill i figured out what electronics and possible upgrades i wanted to use in it.
I finally decided to use a new, stock Torox 185 /Kuron 825 6s system, a Flysky receiver and a DS3235 servo.
I already have a modified Radix and a Typhon build that i mostly run when i visit @Rotauq on one of his track days.
So i decided not to upgrade anything and keep the Spark mostly stock this time.
After my first test run on the beach i usually run, the brand new servo already died.
So i put the car back on the shelf.
Yesterday i found the time to replace the DS servo with an Yipin servo.
And while i finished it all up, i found this:
Well, we were talking about cap's popping last week. This one certainly popped.
Id did, didn't it?
But this one is brand new. Just one run on it on a 16t pinion. That's what i've been running in the other 2 buggies, with the same ESC's, without problems.
Id did, didn't it?
Magic smoke = released! 😝
If that ESC is outside of it's warranty - just solder in a replacement cap. Doubt it would cost more than £1 to replace. 👌
It's waterproof. I bet everything is epoxied.
If it's not, my soldering is still not good enough for that.
Yeah, that's a very good point - it's all epoxied in. 🤦
I suppose the issue is - what else went wrong to blow the cap? The MOSFET might be toast anyway. 🫤
I have no clue.
It just had one mild test run and it ran fine.
I did not notice anything out of the ordinary.
Congrats, I can attest that Horizon Hobby is much soooo much worse than Corally for warranty.
I always hated soldering the bullets of a EC5 connector on. I always got too much solder on the outside of the bullets to put the blue cap over them.
I ended up just putting the bullets on and ditched the blue caps all together.
A while ago, i found a set of 25 male IC5 connectors, so i tried them out.
They are so much easier to solder, i am putting them on all of my esc's.
I still melted some, but there's plenty left in the bag.
