Kagama Horatio's/Chris With A C's Kagama LE -
Stay tuned! 🤩👌
How will this stack up? Kagama LE, Kronos XTR and Kraton EXB V6 shootout - here we come! 😎
Shout-out to Rutt Rider who kindly brought the Kagama LE to SWRCCC at the weekend racing series round 3.
Pit table absolutely upside down and everything happening all at once. 😅
First job will be to install a FASST receiver and an XT90 battery connector.
Otherwise, I'm going to be running it completely as it arrived. No mods to this one.
First job: centre diff. Front O-ring is blowing oil, so I'm rebuilding it with new o-rings and green slime. Standard RTR issue and fairly common with the Corally stock diff.
Where the flimsy red O-ring sits (part C-00180-182) sealed up with green slime, as well as the inner part of the O-ring where the output shaft passes through.
The steel shim now sits on top of an impermeable layer of green slime. It's sealed now. Nothing is getting out.
It's important this part stays clean and that the holes for the screws don't get contaminated with diff fluid - otherwise your screws can back out.
I'm running with 100000wt - stock LE centre diff. Let's see how it goes with this.
Cause of leak:
The inner edge of the O-ring is marred. Either due to a burr, or possibly because the O-ring itself was malformed to begin with.
Have you bought it or just having a play with it?
It's a permanent addition to the fleet! 👌🤩 Chris has other projects that he's focusing on with his channel and he's back racing again now.
Kagama LE no.660 is now a Horatio project. 🤩
It needs a FASST receiver and a decent AGF 81BHMW. The current Spektrum S665 is marginal. The stock servo saver spring is extremely soft, so before I install the servo, I intend on upgrading with the trusty Lee Spring. 💪👍
I have the A73BHLW v2 in my LE and find it has more power than the Lee Spring can transfer reliably. Can you post a video and provide impressions of the A81 after install?
I broke the output gear on three Ipin GX3255’s before giving up on them. Hopefully the AGF servos last.
Here are the gears of the Ipin vs the AGF beside each other. The AGF are significantly wider.
Finally, AGF provides replacement gears. I ordered two sets.
Good to know about the YiPin/GX servos.. I have looked at them several times but never pulled the trigger. Also the AGFRC, just can't stomach the pricing. I can't see spending that much on a servo. I've been buying the DS and it's variants for about 6 years now. I know they're slow and likely not putting up the advertised torque but they're cheap as chips and out of nearly a dozen of them I've only had one (I think) failure. More than I can say for TC's servos, every one I or my brother ever had gave up almost immediately. Granted they were all RTR servos.
I have some spare AliExpress springs if want to try 1 them but as the Lee spring is your baby I understand if just want to go with it
I have a spare set of gears been in the toolbox 2 years 😉
I've not broken a GX3255BLS yet, whiles having them in many of my cars. Bad luck? Or maybe i am to nice with my cars. :unsure:
The GX3255BLS seems fine so far in my spark on stock tires. Bigger vehicles or bigger tires with stronger servo saver and then I see failures. I wish I could buy gears for that servo but I can’t get in contact with the company to ask.
I'm down for trying an Ali one - PM me a price and I'll make it right with you. 🙏
Somewhere I have a Lee Spring - but after the move - lord only knows where it is. 🤭
These Ali springs are 100% better than stock, right?
I recently bought a 1/5 scale yipin (R80Pro) and it actually had a spare set of gears in the packaging.
Buy right - buy once! 🤩 I'm yet to kill an AGF servo, even in high speed carpet racing (no servo savers!) - across 4 different classes! Brilliant servos. I'm running 2 low profile, 1 Mini (front mounted) servo, multiple 81BHMW's -which I have to say perform brilliantly - precise and quiet. The hall sensor and brushless motor is a great combination.
As Knowair stated - the prices lately are eye wateringly high. So too are the Protek Black Label 170 SBL & TBL 🤦
The thing is, if people are running high response radios, receivers etc - decent servos aren't really optional
AGF gears are $15 so even if you don’t strip them, you can freshen up the servo when they develop slop. I think part of my issue is I run my cars a lot more than most folks and I wear the gears and the resulting backlash created leads to an increased peak loading, resulting in failure. I say this because before failure, I notice a lot of slop at center for the Ipin. With no spare gears, I have no choice but to run it until it fails.
If you can measure, I’d be interested in how thick the main output gear is on the A81.
AGF A73BHLW v2
Ipin GX3255BLS
The one DSS brushed servo I bought lasted a long time. It never failed but the gears are worn out.
Now before any new servo goes in - here's a couple of observations with the Kagama LE, compared to the EXB and XTR.
  • It's extremely well engineered
  • Parts are fit extremely precisely with multiple points of contact
  • The steering bellcranks are incredibly smooth and precise
  • Taking stuff apart isn't is as straightforward as the XTR or the EXB
  • Even when you undo what you think are all the screws for an assembly - there's always a 'thing' elsewhere with a crafty hidden screw. Doh!
  • The plastics are totally different to the Kronos. Very strong indeed.
  • The instruction manual are generally quite good, but disassembly of the front chassis brace actually left me wondering what I was doing wrong.
  • Likewise - removal of the steering assembly isn't as straightforward or as intuitive as other rigs.
  • Kagama LE servo saver is just as good as the 2021 versions - if you like no steering. (It's terrible).
  • EXB steering is significantly more positive
  • XTR steering with Lee Spring is wildly better than either of the above in the steering department
  • The only way the Kagama will drive the way it's designed to is with a decent servo and positive servo saver
  • Alloy bulkheads with the LE are extremely nice, but necessitate more careful maintenance and greater reliance on threadlock, much like the EXB
  • These 6S RTR rigs are entirely unsuitable as a first RC truck - fun though they are
Atomic skull measured them at
Stock 25kg
AliExpress 40kg
Lee spring 50kg
The AliExpress springs are like £2.50 for 5, I ain’t even gonna charge you for price of a stamp 😂 I was going to say I think I still have your address but if you’ve moved best send me your new one lol. I’ll get it in post Thursday nightshift atm
Scorched rc sells them best price I’ve found for them
https://scorchedparts.co.uk/products/agf-55kg-advanced-brushless-digital-servo-a81bmwp
