Syncro Syncro 4 adjustable motor mount upgrade.
Hey, just a warning to people upgrading their motor mount. don't do what i did and get the wrong bulkhead. I bought this set: Team Corally Motor Bulkhead V2 Aluminium & Motor Mount C-00180-605 C-00180-177
The 177 adjustable mount is correct but the 605 bulk head is the wrong size.
It was the only one for sale and i just assumed it would work. Which it does but you have to add so many spacers to get the right height with the opposing bulk head.
You will want the c-00180-176 and the 177.
https://corally.com/en/product/C-00180-176/
This is a link to the correct bulkhead for the motor mount.
That’s for the 52t spur where Syncro 46t so the the diff will fit but the diff mount to low then on one side. They all use same diff mount but the vehicles with 52t sour have a spacer underneath that’s the part you would have needed to make it work. C-00180-562
Hi there what size pinion in spur are you using, same as a stock syncro 4? Did it work out in the end with Nelson.81s suggestion? Thank you
Hey sorry for not replying.
I used the c-00180-176 bulk head and the 177 motor mount in the end. With the stock diff mount.
46t spur. 15t pinion.
