I totally follow the train of thought by OP. It boggles me how we still have a Dementor to this day. My ideal SWB truck is the Kagama parts with a short wheelbase and optionally smaller than 170mm tyres (closer to the Arrma Backflip LP, 158mm), which I use on my own Arrma Notorious 6s V5. It is a monster of a truck when it comes to flipping and it is my favourite by far. However there are weak points - Drive cups not S2 / Spring steel, generally the drive cup section and the CVD cross pins are prone to popping out. Also, the Pillow balls would come out of the knuckles, and maybe the rear wing mount is too prone to breaking, tearing off the wheelie bar attachment. All bearable issues, as such I love it to bits and would love to have a Corally equivalent whereby I can go longer in between diff rebuilds. I am convinced my bulkhead screw holes can only sustain 1 more rebuild before it strips.
One that is probably slightly narrower as the full sized Notorious is too darn wide for my trolley:
Nowadays to prolong the inevitable diff rebuild I am even running the Noto with 5S, to similar effect. I don't need to jump roofs.
I'm currently waiting for the holiday season to buy and build a Kagama 4s with above mentioned specs but it would be better if the spring steel drive cups are included in a short wheel base 6s version that I can down spec instead of up spec. Saves a lot of wastage as I won't have parts that I don't want / need.
