Trucking in space
Anyone have any experience with this brand? It was the only 10t pinion I could find, but it lasted maybe 1.5 packs and one top of the visible carnage, the set screw head stripped.
My mesh must have been very loose for this damage to occur so soon, correct?
I have a Tekno 11t that I'll replace it with, but my only thought is my mesh was way too loose.
Any thoughts on this ?
I had another pinion that stripped very early (stock 13t) and I had the idea my mesh was loose then as well, since it got the "shark fin" effect, (I think that's what you call it) where the teeth were worn in a sort of curve on one side.
But this Redcat pinion was demolished. I walk 15 minutes to my bash spot and it started to sound funny (the gear noises) 3/4 of the way there. After 10 minutes the sound was like a well-muffled tiny 4 stroke engine.
I started walking home, was dumb and took it on the grass in the last 3/4 of the way, and it fully stripped.
I must be calamity Jack (and a poor builder) because I have an issue every run. I'm not complaining, just trying to learn as I go.
But it's slow going.
On the plus side, the new servo worked excellently. Turned on a dime. I also noticed I forgot to thread lock the pillow ball retainers when I changed the CVD. These heavy Badlands with aluminum hex inserts play help on my wheel adjacent parts. The right side is not loose at all, so I'm hoping it's not too much extra weight, it's me forgetting thread lock.
Thanks in advance for the input.
