The gears are stripped. It's time for a diff rebuild.On my Sketer the front diff turns easily, the center diff turns easily but the rear diff gets hard to turn in two spots each revolution off the main shaft. What would cause that?
I remember a year ago or so another member had a similar issue, if I recall his would have a bind with no load but if the suspension was compressed it was fine, he was convinced the dog bones were too long, may be worth looking into that area, if yours acts the same as his start messing with camber or turn the droop screws a bit to lower it to a level that doesn't bind maybeOrdered a new diff assembly from Jenny's. Was half the price of a new diff part. I was running through grass but wasn't bashing can't imagine how I broke the diff on the first few runs.
That actually makes more sense. Both the arms lift slightly as it goes through the tight part of the rotation. Will look into Camber and Droop.I remember a year ago or so another member had a similar issue, if I recall his would have a bind with no load but if the suspension was compressed it was fine, he was convinced the dog bones were too long, may be worth looking into that area, if yours acts the same as his start messing with camber or turn the droop screws a bit to lower it to a level that doesn't bind maybe
There's a good chance, with the rear module removed you probably have a rather exaggerated angle to your arms you normally wouldn't have when installed on the vehicleTurns out it is droop related. When unloaded the dog bones bottom out in the cups. if I push the arms up a bit it turns freely. Wondering if this is happening because I have the rear assemble removed and might not happen once reattached.
Corally CVD's for the XTR still have dog bone ends at the diff output side.Why on earth they still using dog bones?
I admire Thunder Tiger's MT4-G3 that used cvd's all around!
There's no reason at all why they should be limited to 1/5th. They would work better than 'cvds'These are interesting.
Only for 1/5 ?
