Muraco build
Sandracer_NL
The Netherlands
  2. Muraco
  3. Radix
  4. Spark
So I got a Muraco this week and need to get it ready ASAP for Saterday’s Arrmaforum 😄 bash day!
Glued tires, taped wheel holes, reinforced the body, used the Dremel on the wheel nuts to serrate them (non-errated wheel nuts?! Come on TC! Booohhh👎). Made a foam patch for the center roll cage mount.
Next: skid plates, add motor fans, change battery straps (longer ones and a 3rd strap) and check the included V2 chassis brace.
Very nice!! Congrats! I really like the handling of the TC stuff, look forward to hearing how ya like it. Enjoy!!👍
I've ran the Muraco on two Arrmaforum bash days and Saturday will be the third.
I have to say I'm impressed. Handling is good. Speed and accelaration is pretty brutal out of the box and I had even set punch down one level! It did 87km/h on sand and I'm not sure if there was even a little more in it, as the 'runway' was somewhat limited by tracks made by 1:1 offroaders.
I have no doubts that on road and with some lighter lipo's (I run 2x3s 8000mah) it will be close to its' stock configuration claim of 105km/h.
Furthermore, as I was too eager to run it, so I did not do the usual 'pre-run' things as check shimming, diff and shock oil levels etc. I did not even change the servo! ;)
I did however, add motor fans as the motor does get warm pretty quickly, and add skid plates. And I'm running my own transmitter.
Overall a big(y) from me!
