Kagama Lee Spring Servo Saver Spring - What you need to know
I've started this thread to make it easier to find all the info in one place.
It all started here with DaniC's post - how to adjust servo saver:
https://www.corallyforum.com/threads/easiest-way-to-adjust-servo-saver.459/
Back in the day, around 2022, Danny and myself measured up our springs and looked for spring manufacturers that can make bespoke springs.
Lee Spring were selected as the manufacturer of choice. Primarily because they make the right spring, but also because they have global reach.
Speccing a simple compression spring is more technical than people realise.
The primary issue with the stock spring is rate is insufficient for the level of force that is generated through the steering. Not only that, but the stock spring rapidly gets weaker during use.
The forces that the steering mechanism has to deal with increase with wheel/tyre weight, rpm, surface speed, higher specced servos, higher BEC voltage and the type of terrain.
Note the rate in this spec sheet: 24.343 N/mm
This means that to compress the spring just 1mm, 2.4kg would need to be applied.
Also note the material choice. Music wire is about the best material you can engineer a spring from as the rate will be consistent over time.
With the stock spring, to get any steering authority at all, I had to really clamp down the servo saver spring until there was very little space between the coils.
The disadvantage is obviously that with very little compression space left, there is virtually no saving action in the event of a 'tumble wumble'.
Having insufficient steering authority isn't an option at 70mph.
So, here's the Lee Spring on the right:
It's wound from thicker wire, with a slightly larger height and diameter. It's an interference fit onto the threaded Servo Saver shaft.
The stock spring can be compressed between the tips of my fingers:
Where as the new Lee Spring cannot be compressed between your fingers. I have a grip strength of 50kg and it wasn't happening! 😅
Here's how the Lee Spring should look correctly fitted:
Note the spring is properly seated on the thumb screw and squarely located into the saver.
Fitting: compression to the spring is required as the thumb screw is carefully - and squarely - introduced to the threads to avoid cross threading. Once the first few threads have been positively engaged, continue clamping the spring until 2 visible threads can be seen.
The linear force of the spring against the thumb screw means that it will not loosen over time.
Since the release of the LE, there are already people experiencing issues and people suggesting additional wheel nuts and threadlock as a fix.
Do not apply threadlock here (for obvious reasons)
Do not apply an additional wheel nut.
To manage expectations:
Unit cost of Spring from factory: £3.66
Admin charge for orders below £30: £12.50
Should an ebayer (such as myself) buy a batch of 10 springs, please bear in mind eBay fees, postage, packaging will all need to be factored in to the final selling price.
The shipping costs:
Shipping from the UK to different regions attracts different costs. Springs have to be sent in shipping bags. Sadly, such bags also cost money.
Please do not expect people to supply these at the buy in price and then incur loss, because this is unreasonable.
Fitted as described, you will have much greater steering authority as well as saving action in the event of a crash.
One cannot expect an upgraded servo with >45kg of torque to perform any differently to a bog standard stock servo, if it is limited to the stock spring which yields at 3kg in either case. It's common sense.
Yet people with floppy servo savers still wonder why their new servo doesn't cure the problem. It was exactly the same story with Savage community over 20 years ago. 🤣🤭
Servos can fail without warning for a multitude of different reasons. Gears can fail and magic smoke can (and does) happen.
The single biggest problem is incorrectly set end points, and sadly, certain RTR radios do not facilitate this adjustment. Combine this with running servos at their maximum voltage ⚡ and the first spike causes failure. Especially on cheaper, unbranded servos.
Over the years, I have bought just about every brand of servo - Acoms, Futaba, KO, HiTec, Sanwa, Protek, AGF RC.
My mindset - if you buy cheap, you buy often.
So, my personal recommendations for 1/8th size vehicles remain:
AGF RC 81BHMW
Protek Black Label 170 SBL
Protek Black Label 170 TBL
I run a 170 TBL in my Baja 5B for throttle/brakes and I have to dial it back on any surface I run.
I run a combination of Protek SBL and TBL in my XT8 and it has such a direct and positive feel - it's scalpel sharp in its response. Perfect centering, which is extremely important - especially when racing.
The AGF RC 81BHMW is comparatively new to me, but I started using them in my Kronos XTR, running the BEC on 6V. 4 years later - it's still as good as new. In the UK, it was supported by King Cobra Racing and more recently - SMD Direct.
I also use one in my Sworkz T2E - it's a great rig and the steering is laser accurate. The AGF is waterproof, HV, brushless - it's very, very good and half the price of a Protek.
I'm about to pull the trigger on a low profile AGF one for my 22x-4 - the A62BHS - with 0.058 speed. Basically faster than anything I've ever used, so will prefer it tamed on 6v to be perfectly honest!
Ensure your servo is OK for BEC use.
It's works a treat got one of the lee springs from the old post and it works brilliantly. Kagama handles like a truck half it's weight with a good servo and this spring. Feels so light and responsive.
☝️ Facts! Cheers buddy. 👍
AGF RC 81BHMW
How about this one?
https://www.promodeler.com/DS635BLHV
They have a patented 5 gear transmission that allows fitting wider gears into the case (takes up the space that's usually empty inside a standard 20x40mm servo case). Apparently they also make the servos used in GPS guidence tailkits for the joint strike munition for the USAF reason being they are basically the only US based manufacturer of small servos that actually makes servos in the US (with offshore sourced components that could be sourced in the US if it became necessary)
One of the cool things about these servos is they are completely repairable, you can order a complete electronics replacement send the servo in and they will swap it for you. As the gears and CNC shell are a large chunk of the cost of a servo this is less expensive than a complete new servo.
If you order in the US it's:
1 spring: $35.46
4 springs: $62.34
5 springs: $44.80
6 springs $53.76
Cost per piece is $8.96 and the handling charge disappears at 5 springs.
How about this one?
These do look really, really nice. I'm sure it's just an advisory to use a separate pack, but by the looks of things, they can draw some serious current. 😎👍
According to John Beech they will work but they will not guarantee the performance specs with a BEC. That said you could put a big fat capacitor or a "backup guard" supercapacitor on them and that would cover the brief current spikes for the most part. Servos don't pull e.g. 15A from the BEC constantly they can't because the 0.1" crimp terminals used in servo connectors (which are usually Harwin M20s or Tarng Yu TY5081s) are rated for 3 amps continuous current and 22 AWG wire is rated for 5 amps. The servo lead would melt if that were the case.
Also I REALLY wish TY5081s were available in small amounts to hobbyists they are much easier to crimp with generic tooling than Harwin M20s which have crimp "wings" around the insulation that is designed for a "U" shaped die rather than a "B" shaped one. If you are going to crimp your own servo connectors you're probably better off getting some Molex SL "high insertion force" terminals and three position housings. You don't want the "standard" terminals with a three pin connector because they won't have enough friction between the pin and the terminal and will easily fall out. What you want are the ones with a "bowed spring" contact area that's shaped like a ) ( instead of the normal \ / leaf spring contact. The great thing about Molex SL is that they are perfectly compatible with R/C equipment pin headers and they crimp well with generic tooling because the crimp wings are box shaped not trianguar.
Installed my new spring in the Spark very noticeable difference in steering, I like it
Good stuff! With the upgraded spring, the benefit of torque and response from upgraded servos can be utilised.
Without it - the weak link will always be the floppy spring. 🤩👌
Because the Lee Spring is slightly longer, it requires about 6kg of preload just to get the nut on. Once secured though, you'll notice so much more space between the coils. And the thumb nut will literally never back off.
On YouTube, a fella here in Wales - Marks RC - tests his new Kagama LE - and guess what? The steering thumb screw has backed off and he had virtually no steering.
One of the suggestions was to use an additional wheel nut and threadlock on the threaded servo saver shaft, thus gacking it all up. Some people, eh! 🙄😬
When it was suggested that an upgraded spring be fitted, there was some talk about the admin charge on orders below £30.
Ultimately, on a £690 LE, I would want it to steer properly. Even if I wanted to be really tight and buy just 1 spring - it's just £18.66! 🙄 Go figure.
Glad yours is kitted out! 💯
I watch Marks’s RC and ChriswithaC along with a few others. TC definitely larger in EU than here in the US but we do have a few that have spoken very highly of TC. One messaged me yesterday saying how TC just doesn’t get the love they deserve which I agree. I think TC does the weak spring as a failsafe for the mass users, kinda like here cars have speed limiters again why I love my Porsche they don’t play that game. Either way the spring is a definite need to upgrade thanks gain for that share
Just installed the Lee Spring to the Kagama4 and Holly crap took me total surprise. Had to learn how to drive her again the steering is so much more responsive even on the stock servo. A total joy to drive, better turn radius and with the 17t pinion just a beast
Something is borked with their US site, it won't progress past "review order" and you can't check out.
Crap I ordered mine last week no issues the site was weird though, have some others asking if I’d purchase and send. Don’t intend to make a penny just whatever costs are involved is all I’d ask for for anyone it’s ok to ship to
If you have any spares I'll buy one off you for cost + shipping
Thought I'd better join the Springers Club! Lee Spring, UK site, despatched my order of 9 (carefully chosen to avoid the handling charge) and I received it in a couple of days.
First impressions - bloody awesome 👍 I'm able to steer around small areas around my lawn and patio. Thanks to everyone involved in finding these 😁
