Kagama suspension on a Spark buggy compatibility
ThaChester
I was wondering if anyone knew if the kagama suspension can be swapped onto a Spark buggy. I see the diff housings are the same. The shock tower mounting looks the same. But I see the suspension arm mounts are different. I was wondering if anyone had any experiance in this. Thanks ahead of time.
Why use kagama shocks? The shocks are longer, you would need to fit longer arms off the kagama, Asuga or any other lwb and change shock towers also.
I was looking into fitting the kagama arms, shocks, shock towers, driveshafts and end blocks.
Yea You can do that, truggified as it’s known look that up you’ll come across plenty builds with it done.
I was looking into fitting the kagama arms, shocks, shock towers, driveshafts and end blocks.Fella on a fb group done it recently on radix
Shouldn't be a problem, I did it to my radix within a month of it being introduced, then like 1-2 years ago did it to my python, granted at that time the kagama didn't exist so I used the older truck stuff but I just recently put the kagama arms and towers on my jambo, all a direct fit so I personally see no reason why you wouldn't be able to fit them right on your spark, corally is pretty darn interchangeable across models. Your spark rear shocks will work on the front once you do the arms and towers so you'll only need to buy a set of rear truck shocks for the back, also if you're planning on running the sway bars the front still works but you'll need a truck one for the rear.
Awesome
Awesome, thanks for the help.
