Kagama Kagama 6S - Feedback and upgrade ideas for future revisions (UPDATED WITH COMMUNITY FEEDBACK, LINKS AND FIXES)
Thank you so much for the comments. I understand the car much better now, I wish I had known all this from the beginning. I hope this post helps others buying their first Team Corally. I already have everything I need to fix the minor issues on the way, and the EXB shocks have arrived me. I'm going to make the car even more amazing than it already is!.
Regarding the wing, from what I've seen, the Asuga wing is too big - 24.5cm, while the Kagama is 21cm. I think the Spark wing would fit much better, although I don't know if it will be stronger than the Kagama LE. I think the Spark wing size is 21.5cm, and it might not get stuck against the body. Can anyone confirm that the Spark wing (I think it's the same as the Kronos) measures 21.5cm?
If you know any other issues and fixes, please, write them in the comments. I will keep updating the first post.
Thanks!
The spark wing is incredibly easy to crack. The Asuga wing fits the Kagama well. If you get (or make) adjustable wing mounts, you can shift the wing back so that the body won't get caught.
Can you share any image with the Asuga wing?
The Kagama of Partydaz look great!
And can you share de 3D file or link of wing support?
I just checked the Syncro wing and it looks exactly the same as the Kagama LE, but the reference number is different. I don't know if the material is different, perhaps using the Asuga support or a custom TPU printed support and the LE wing would solve the problem of getting stuck, but I would like to see how the Asuga wing looks on the Kagama
I shared my 3D print files in a 3D print thread on this site. If your only concern is the body catching then trim it slightly?
That's what I had planned, to trim the bodywork a bit, but it's the LE version and I'd rather not cut it. And btw, I spoke with support, and they told me that the LE plastic compound is different from the others, description says PA composite but harder and theoretically easier to break, while the LE is much more flexible. I'm going to design a 3D print mount that raises the wing slightly and moves it forward, so it looks the same as when mounted with the Asuga mount, I really like how it looks.
4. Better shocks out of the box, the shock are good, but they could be better, emulsion type, thicker stock oil (at least 1300CST) and stiffer springs to improve landing absorption, make the suspension more progressive and avoid having to buy the EXB shocks. It’s a basher designed for jumping!
Fix: Buy Arrma shocks V6 or EXB
Ugh no, emulsion shocks are awful I hate them. My Baja 5B uses emulsion shocks and they are disgusting.
Can you explain why you hate them?
I had EXB shocks in a Muraco and now have them in a Shiroi, but i don't notice much of a difference.
Hey guys, I wanted to share the upgrades I've already made to my Kagama LE: EXB shocks, Notorious 6S wheels, Shiroi front bumper, flat-head downstop screws and I’ve also designed a 3D printed TPU wing mount, the wing is now 8 mm further forward and rests on the shock protectors, so it can’t get stuck.
The shocks protectors are also TPU 3D printed, it's my own design. I also tightened some loose screws 😅 and adjusted some parts with washers.
I still need to replace the front steering links with the plastic ones from the standard version, practically in every session the steering block arms (C-00180-207) bends and I just hope that the flexible plastic steering link doesn’t end up bending that part.
I'm also designing a wheelie bar, I'll have it ready to test soon. I don't like the TC one.
And I'd like to add more durable CVDs and dogbones, but I can't find any third-party brands that make them or any compatible ones from other cars. I don't know if the carbon fiber parts on the arms will help make them harder to bend.
These will fit but haven’t tried them so don’t know if they any good or not. If your on Facebook Erik van Ravenstein does titanium Ackerman set includes steering end plates
I just found this on AliExpress: | JSS Upgrade HD Hardened #45 Steel Front Or Rear Drive Shaft CVD 2pcs Team Corally Kronos C-00180-341 C-00180-346
https://a.aliexpress.com/_EHfNyHY
If my friend with the red Kagama LE doesn't make them (he has CNC), I'll write to Erik to see if he can sell me just the parts I need.
Regarding third-party CVDs, I'm not very confident in them, if anyone tries them and finds them more resistant, please let me know.
I also wanted to ask if adding carbon fiber plates to the arms would make it harder to bend the dogbones and CVDs by increasing rigidity of the arms, What do you think?
Thanks a lot for the info.
On my spark, after my first new style cvd broke, i've started to switch over to these FTX DR8 universal joint shaft:
(Credit to @Sandracer_NL for the idea)
I can't judge yet if they are much better, but considering the DR8 is a tank, it's very likely they last longer
Ackermann plate on the spark is also a weakpoint. I'm currently running my third already.
Next i will try this ADU racing version: https://nl.aliexpress.com/item/1005006764884257.html
Since they last a long time in the DR8, I expect them to also last in the Spark.They already have quite some runtime on my Spark 👍. They do need a few additional shims, but that’s it.
I bought some of those from Ali Express after you mentioned this.
I have not been able to fit the bearings on.
I remember it wasnt easy indeed
Hmmm the bearing size on the FS Atom are identical DR8 and Corally cars. Can’t remember, but maybe it needed a tiny bit of high grit sandpaper; the inners diameter on all bearings is 8mm.
I had to sand all the anodising away till the bare metal, and then some, to fit a bearing on. That bearing is going to rust solid to the stub. I guess that's a future problem.
One done, three more to go.
A bit of silicone spray helps. I try to avoid grease as it attracts a lot of dirt.
