From a fully charged battery, using a known load (ie 20amps) and measure the voltage drop.
Calculate the resistance by: Voltage drop / Current
Then, using the accepted maximum voltage drop per cell limit - 0.5v/cell (500mV/cell) -
500mV / internal resistance
(Example - 500mv / 8 milli ohms = 62.5A)
If your pack is 5000mah (5Ah) pack, your continuous C rating would calculate as:
62.5A / 5Ah = 12.5C
Real world continuous C numbers are much, much lower than you might be expecting. Especially as the internal resistance creeps up with older packs.
Newer, fresher cells have a higher continuous C rating.
In the above example, imagine a new 5000mah pack with 4 milli ohms internal resistance
500mv / 4 milli ohms = 125A
125A / 5Ah = 25c
The take home is this: If you have a charger that can accurately gives you internal resistance, lower internal resistance = better C rating. You can save yourself a whole lot of bother simply by understanding this relationship.
There are a lot of instances where the capacity of the cells are complete fiction too. So test and see what your packs actual capacity is - to the LVC - and you'll be very surprised what the real world, useable capacity is.
