Get a Tekno et48 2.2 or wait for TC to drop a 6s mt/t?? 😬
I suppose any modern Racing Truggy will run rings around 6S bashing trucks.
My Sworks T2E I run on 6S. It's wildly fast and nimble. Beautifully made. Same factory as Sparko.
Racing Truggies are lighter, have better weight distribution, lower CoG, better shock packages, less bracing and race oriented geometry. I'm pretty sure the T2E would smoke any of my 6S trucks - even on 4S.
Of the 6S rigs, I still say my Kronos XTR 21 is the best handling out of the Kagama LE, Kraton EXB V6.
As an experiment - I even ran the XTR on an indoor carpet track, in with 1/10 buggies. It was hilarious. 🤣
Sadly, it's not allowed, so I won't be doing it again. I can't afford to replace the carpet either! šŸ˜
The 1/10th buggies might be quicker around a track, but the XTR is impossibly wide and impossible to pass. 🤣
I regret selling my XTR 🄺. Also would have loved to see that haha. I plan on rigging a horn on a truck for fun and annoyance purposes šŸ˜‰.
Ive had my eye on the Te2 but its old right? Discontinued now?
Now if there's a massive jump by all means ima gonna send it! Lol but mostly I like to keep the rig grounded and just rip trails like pole line roads. Im not trying to reach the moon like some tubers try. So with that being said which one would you go with?
Where are you located? US?
Here it is.....
Sworkz T2E Evo
Very much alive. And very &_Ā£#ing expensive! šŸ˜…
I have found one in the states... absolute beaut! I don't think it'll handle alot of bumps and sh!tty driving like the et48 may.. though I do need a road rig.... also need to do something with what I have..M2C beefcake for kagama...šŸ¤”šŸ¤” lol.
The 4s backflips. It’s a quick truck, runs circles around my Kagama LE. Honestly it’s perfectly matched to 4s. It’s more durable than my 6s corally’s on 4s. The things I don’t like are the small battery tray and the body situation. I’ve been practicing front flips and my failed attempts do a number on the body with no center support.
WHOA easy with the TC trash talking šŸ¤£šŸ¤£šŸ˜…šŸ«£. So more durable then the shiny LE bits? Currently Jennyrc looks to have LE bits i was tinkin of snatching
I don’t want a Kraton but I would like these new bulkheads from scorched for the Kraton. Why this hasn’t been done before I don’t know or maybe I’ve just never saw it before. But someone needs to do it for corally šŸ˜…
https://scorchedparts.co.uk/product...-zero-degree-for-all-arrma-6s-1-8th-and-1-7th
It might be better to say more durable than TC in some some ways while my Kagama LE is more durable in other ways. If you want a short wheel base "stunt" monster truck, I like the MT48 more than the Kagama LE. If you want to run 6S in a monster truck I like the LE better.
Definitely a good idea. I know this is Corally Forum and understand that most here prefer the Corally brand over Arrma but I have had less driveshaft issues with my Arrma’s than my Corally rigs.
I would love to see these bulkheads injection molded for say $20 or $30 over alloy cnc for $125. I have no need for alloy bulkheads.
Ive always been curious. If you get an alloy case is there really a need for alloy bulkheads? Would it be better to have alloy a-d blocks?.... still new here lol haven't had time to understand everything as much as possible...YET
For all out durability, I would say alloy for all those parts. However it does come with penalties, weight and cost. Both Arrma and TC use alloy plates (or steel in some Arrma) on their ā€œblocksā€, they are generally just stamped 6000 series alloy in the base 6s models. I find they do wear rather quickly.
The alloy cups and bulkheads are great for overpowered setups as they keep everything nicely aligned and are more heat resistant (cups). Stock power doesn’t generally need these parts in my experience.
My use isn’t typical bashing, mainly track running. However, a good track setup will definitely put a lot of stress on the drivetrain and even the suspension gets worked pretty good.
With my Arrma’s it’s always the diff cups that give up first, followed by the diff gears. I don’t do much in terms of diff maintenance so some of that is on me.
On the TC it’s the center drive shafts that wear out first, then cvd’s. Diffs have been great overall. Center diff tends to leak.
The TC spring steel output cups are stellar, wish Arrma offered something similar. I run TC input cups on Arrma diffs, the outdrives would require some retrofitting.
Center diffs are fairly easy to swap, motor mount on TC must be a bit thinner or different offset as using a TC center diffs in an Arrma doesn’t give the best mesh between pinion and spur. They’re slightly off, I’m not getting a full contact between the two gears.
