I have a program card, but i wanted to know if stock the model is to 7.4 v or need to set because is to 6 voltI used the Hobbywing LED programming box on my Torox185, otherwise you'll need to count the beeps/flashes to set it.
According to the Torox 185 ESC manual, the default voltage is 6.0V and a 7.4V is an option. I have changed the BEC voltage to 7.4 on both my Radix6 and on my Muraco, which is just a different body on a Shogun chassis.Hi guys, I recently have got a shogun, regarding the servo, is the esc able to set 7.4 volt? How is set on stock the model?
Thank you
Not really. The additional speed and torque cannot easily be detected.Thank you, did you notice much different between 6 and 7.4?
