Kagama Dusty Motors shroud
trippinmunky
Australia
Hi,
Now I have my Kagama 6s running well, I hope I want to get one of the shrouds but I am a bit confused what size to get.
I have measured the chassis and it looks around 34cm to me
Dusty Motors website says I need universal L - https://www.dustymotors.com/shop-pa...e-protection-cover-size-l-for-corally-kagama/
Hobbies Direct tell me I need the universal XXXL - https://hobbiesdirect.com.au/produc...sal-xxxl-black-protection-cover-uni0081-37244 but that is also referencing Arrma
So much cheaper on Dusty motors website as well
Or if I go for a cheapy amazon / ebay one what size should I look for?
Also has anyone 3d printed anything to go here to attach a shroud to and stop crap getting in?
If it fits a Kraton or a Sledge it will fit your truck. I run a Notorious cover on my Punisher 4 and Tekno MT48. The fit isn't perfect on the back end but the covers still make a big difference. With the Tekno the side rails don't go all the way to the end of the chassis on the back. It leaves a gap just in front of my rear gearbox.
This is just an assumption, XXXL I assume would be a Big Rock which has a wheel base 1.5 inches longer than a Kagama.
I recommend going to the Amain site and searching "Kraton cover" and getting some part numbers for what looks interesting. When your at Dusty Motor's or wherever you'll know what your looking at.
I have ordered 2 from aliexpress to try
1 for Senton 6S
1 for Kraton 6S
so will see how they fit.
Was doing some AI'ing and that reckons the dusty motors XXXL should fit over my motor twin fans and the rollover tower as well so might get that to try as well
Horatio runs the large says it’s a tailored fit so xxxl I can only guess will be way too big but Kraton one you’ve ordered should fit
Do you know if the L fits over the rollover tower?
As far as I can see the L and XL are sold out worldwide so that is the only reason why I am considering the XXXL as that is the only one in stock in Australia and I can get it next day
The aliexpress ones will take 2 weeks or so to arrive
Looks like it , it’s what Horatio has on his in the pictures on that link. But it depends on brand of the dust cover , have saw others with xxl & they fitted also so guess it’s just a case of check dimensions when ordering & 🤞
His car is a Kronos which looks like it has a slightly more compact chassis and smaller rollover tower to me
But yeah the XXXL will probably be too big
The Kronos and Kagama are identical size.
You don't need an XXXL shroud for your 1/8th rig.
L would be fine.
Dusty motors shrouds have a zip up the middle, so your centre roll/body support can poke through if you prefer. 👍
