Droop screws suck
Atomic Skull
So has anyone else had the droop screws gradually eat holes in the aluminum flange? There needs to be a hard surface there like a washer or a screw head in the chassis that the setscrew can rest against. A 3mm flathead screw would do the job. Just seems like a dumb design I could see how it was going to fail right from the start.
Same here. I put some Tekno droop screws in my Sketer. They are wider. Problem solved. Think i am gonna do that for my Asuga 2
I'm thinking I'm just going to drill and tap where the pit in the aluminum has developed and put another setscrew there.
Avid do titanium droop screws, 2 different types 1/10 & 1/8 both fit I bought 1/10 by mistake but still work.
https://www.avidrc.com/product/5/ac...Screws-8th-Scale-4pcs-AV1813-accessories.html
My problem with those is they are going to limit your available droop because of the domed head
I found this cheap option: https://www.amainhobbies.com/hb-racing-d8-v2-droop-screw-4-hbs204860/p1502276
And these more expensive ones:
https://www.amainhobbies.com/j-t-be...titanium-droop-screw-set-jtb-jt10907/p1500300
https://www.amainhobbies.com/revolution-design-titanium-1-8-droop-screw-4-4x12mm-rdrp0646/p1568437
And also these cheaper ones:
https://www.aliexpress.us/item/3256805131174607.html
https://www.rc-tworks.com/products/tp-087-64-titanium-down-stop-screws-4pcs
The low head will still limit your maximum droop but you need to limit it to prevent the steering hubs from binding on the balls at full droop anyway.
They don’t limit your height there’s enough room check horatio’s kronos xtr build he has them installed, or there is also the 1/10 version which also fit, but those you’ve listed will work just the same whatever your preference
Check this;
These are what you need for droop screws. Steel on aluminium alloy chassis is always going to gouge. These dome heads don't damage the chassis and titanium is softer than steel.
I run these on my XTR and T2E. 👌
I just bought these bad boys on eBay for practically nothing they're going in right now.
I’ve avid titanium ones in mine but also came across these ones, or corally have new ones on sbx825
https://klinikrc.com/shop-1/ols/products/klinik-rc-titanium-4mm-droop-screws-4pcs
My choice too! 😎
They're not cheap, but I don't care. 😝 Cheaper than a replacement chassis. 🦉
Which reminds me - I need to find an ingenious way of fitting that beautiful Scorched Parts centre front driveshaft that you sent me. 😎
Hold them in a certain way and you can see the amazing rainbow colours.
My choice too! 😎
I’ve got scorched parts in my shopping cart few bits out of stock stopping me pulling the trigger. Vitavon & corally 7075 parts inbound too 😉
