Are the springs that TC uses around the stub axles reusable? Guessing not based on the c clips you used. I see TRX has a similar setup on the sludge axles.. back in the day, we used to use o rings on the Thunder Tiger mt4 to keep those pins from falling out. Redcat Kaiju uses a plastic sleeve to retain the pins..the arrma pin fits I had to put two c clips on the cvd to hold the pin in and just dremel them down a bit
when you take the spring of its no good it ends up stretchingAre the springs that TC uses around the stub axles reusable? Guessing not based on the c clips you used. I see TRX has a similar setup on the sludge axles.. back in the day, we used to use o rings on the Thunder Tiger mt4 to keep those pins from falling out. Redcat Kaiju uses a plastic sleeve to retain the pins..
Thanks, that's how it looks. Haven't had to take one apart yet. Good to know.when you take the spring of its no good it ends up stretching
