I need to change the chasis in my Dementor and I have an idea and few questions. I'd like to convert my Dementor into a truck with a longer wheelbase, like Kronos or Kronos XTR. I've read the parts lists for boht Dementor and Kronos and have a few more questions. Front and back apears to be same for both of this trucks. Main issue is longer chasis.
I made a list of the parts I need:
C-00180-328 - Chassis - Long - Truggy XP RTR - Aluminum - 1 pc
C-00180-715 - Drive Shaft - Center - Front - 85.5mm - Steel - 1 pc
C-00180-713 - Drive Shaft - Center - Rear - 170.5mm - Steel - 1 pc
C-00180-105-2 - 2 Shock Tower Brace - Body Mount - V2 - Rear - Composite - 2 pcs
C-00180-103-2 -Chassis Brace - V2 - Rear - Composite - 1 pc
I have a few questions:
Is there anything missing from this list that I need?
Does motor mount [V2] has the same spacing for screw holes as in the previous version [ I have V1]? Thats is my main concern. Currently running Motor Mount V1, 7075 Center dif bulkhead and metal center diff. Im assuming that center diff and bulkhead are compatible with Kronos chasis but im worried about motor mount.
Do i need new Center Front Drive Shaft? In manuals for dementor and kronos thare is 2 different drive shafts for center front, difference is like 1-2mm of lenght,
Do XTR Chasis and brace are worth extra price? Or plastic braces are enough ( currently running tower to tower center brace with extra tube for longer chasis)
Has anyone done this conversion and have any thoughts and tips?
