Battery Voltage after LVC kicks in?
Fireblade
England
  1. Kagama
  2. Radix
I've got 2 6S packs and one seems to hit LVC sooner than the other, so I since I now own a multimeter which basically makes me a qualified sparky I thought I'd throw it across them both to compare.
One was at 22.4v (3.76v per cell) and the other was at 23.4v (3.9v per cell)
Neither was anywhere near the 3.1v that LVC is set at. Why?
You’re seeing combined or averaged voltage acrossed all cells most likely, however it is possible to check each cell’s voltage through the balance connector I believe.
My guess is voltage sag under load. How soon after hitting LVC did you check the pack voltage? They will come back up to “resting” voltage after some time has passed.
I’m guessing that not all cells within the pack are reading the exact same voltage after hitting LVC? There’s always some variance across the cell voltages within a pack. In general the closer the readings from each are to one another the better “matched” the cells are. Separates the good battery packs from the cheap in general. Cheaper packs aren’t as well matched across the cells as higher quality “matched cell” packs.
Typically as a battery ages and has more cycles on it one or more of the cells start to build internal resistance (ir), once a pack has a cell (or more) with higher ir, it will eventually trigger a “false” or premature LVC response from the esc circuitry.
Cheers for the explanation, I for the first time used the ir function on my charger
Black battery - 3,4,5,5,4,4
Blue Battery - 5,4,4,4,48,4
Voltages on both packs are within .02 volts
The strange thing is, it is the Blue pack that seems to last the longest.
