Anybody knows where this rubber bushing came from?
rdevalk
Ouddorp Zuid holland
  1. Jambo
Anybody a idea where this rubber bushing came from?
Just took the center diff out and this fell down. The small white rubber bushing
It might have come out of one of the drive cups. O rings or bushings are often used inside the drive cups to remove slop from the driveshafts.
Should there be one in every cup? because I only have one! with the driveshaft from center diff to rear it was on center diff side.
Yes but there's only one at the driveshaft from center to rear. From center to front there's none. is that a problem?
And I don't see them on the Corally site to purchase
If there's enough room, one in the front diff input cup would be my choice.
With the slightly downwards angle of the diff, and the height of the diff cup, a small o-ring in the cup just stopped the shaft from fouling the edge of the cup and groove.
But make sure there's still enough float, otherwise the shaft might get bent as the chassis flexes.
