Atomic Skull
- Thread starter
- #21
$8 shipping to send it back, pretty much not worth the trouble.
It doesn't, though.Problem with shimming it up by 0.7mm is that is that it would also raise the two horizontal screw holes in the front by that amount so they wouldn't fit instead.
I'm not sure how raising the back is going allow the screws at the front of the plate to thread in smoothly though, the problem is that the screw holes are too low. I'm not saying you are wrong as I have not tried this, I just don't see how that would work. Even if it does not shimming the front will result in a crooked steering plate instead so no matter what my OCD is triggered and I loose sleep.It doesn't, though.
When i mounted the plate without the washers, like you, i also couldn't get the upper hinge pins in. So i loosened all screws a tad and tried again. I noticed that with the hinge pins in, there was that 0.7mm gap on top of the steering rack. If you try to close that gap without washers, by screwing the plate down, the hinge pins are getting stuck. And that basically also pulls the shock tower back, so there's tension we don't want. So i put washers on top of the rack, to close the gap and release that tension. Problem solved.
I agree now, it's not 100% perfect machining, but it's a problem we can easily solve. So not worth the hassle of returning the item, for me.
Edit: I never considered this a problem until you made me think about it with this thread.
Thanks man.![]()
That's not how I roll, 15 years of flying large R/C helis has instilled an insistence that things should be "right". Because on a 700 size helicopter with a 1.5M rotor if it's not it could kill you, or someone else, or put you in a lot of debt for property damage. Hard to unlearn that. And lets be real a 70mph capable 12lb land missile is no joke either.Only if you crank that plate without the washers underneath.
You're overthinking this, my man.
Just assemble that front. You'll see.
I haven't had any problems at all, since it's in.
I haven't checked but I suspect it's only the hinge pin holes and that the shock tower screw holes are correctly positioned because I did not notice any trouble getting those screws to thread. Because of that those holes would be moved up 0.7mm too high if I shim the plate up by 0.7mm.@Atomic Skull on your pictures you show the ADU higne pin holes sitting lower compared to the bottom of the plate. This in itself could be fixed with washers. The problem you are pointing out here in your later comments is the screw holes that mount to the shock tower are also lower compared to the hinge pin holes, correct? You haven't show any pictures comparing the ADU part to the corally part with the brace on top. If the distance between the screw holes that mount to the shock tower and the hinge pin holes is also different you should suspend both parts at the hinge pin holes and then compare again. If you compare from the bottom, then that 0.7mm that could be removed with a washer carriers through to the screw holes.
You don't shim the plate up. That's what i am trying to tell you.Because of that those holes would be moved up 0.7mm too high if I shim the plate up by 0.7mm.
It is still wrong. It will still cause the hinge pins to be non perpendicular to the shock tower. It will still apply force to the diff housing through the shock tower by means the the hinge pins being pulled down in the shock tower holes. It is wrong engineering, full stop. I don't know how else to say this.You don't shim the plate up. That's what i am trying to tell you.
When you mount the plate to the bulkhead and tower, the under side of the plate is over the steering rack, leaving a (0.7mm) gap.
You put washers on top of the steering rack to fill that gap. Not to move anything up.
If you don't put washers there, cranking the plate down, will pull on the entire front assembly. That's why you couldn't get the hinge pins in.
If you do put washers there, everything will sit and work correctly.
Edit: the plate should have been a bit thicker to not leave a gap between the plate and steering rack. Since it is not, i used two washers on the rack.
It is wrong engineering, i agree. But no. If you shim with the correct thickness of the washer, there's no play, no tension, no force.It is still wrong. It will still cause the hinge pins to be non perpendicular to the shock tower. It will still apply force to the diff housing through the shock tower by means the the hinge pins being pulled down in the shock tower holes. It is wrong engineering, full stop. I don't know how else to say this.
