Do not fold the antenna! The antenna will ‘curl’ itself inside the recever box.Oooooooh smart.
Maar dan moet je bijna alles "opfrommelen", is dat goed voor de antenne?
Aaaahhhh!!!Do not fold the antenna! The antenna will ‘curl’ itself inside the recever box.
Just pull the entire antenna through the antenna hole of the receicer box top plate. Then just push/slide the antenna back untill only a small part is outside the reveiver bix, about 4-5 cm. That way the antenna cannot reacht tthe pinion and spir gear..
is it my colorblindness or is your green different than the regular?View attachment 11811
Got it, building right now. Working on the click clicks.
The real antenna is only the is the top part of the wire, part without insulation (3.1mm or 62.5mm)Oooooooh smart.
I’ve been waiting for Asuga rollers to be in stock in the USA since June. I bought a spark instead but have an Asuga on back order. Clearly they may never be available here.Pulled the cash trigger, bought a green Asuga roller.
300 euros incl shipping to the NL.
I think I need some guidance for mounting a motor, when are the spur and the pinion too tight/close?
I didn't understand the explanation from TC, by putting a piece of paper in between.
Who can explain it with simple words?
You can buy them directly from the TC website, they have them in stock.I’ve been waiting for Asuga rollers to be in stock in the USA since June. I bought a spark instead but have an Asuga on back order. Clearly they may never be available here.![]()
Damn, so 439 euro, without shipping is 521 USD.I’ve been waiting for Asuga rollers to be in stock in the USA since June. I bought a spark instead but have an Asuga on back order. Clearly they may never be available here.![]()
Good for you, imho this darker matte look on is way cooler than the bright green color i've seen everywhere.Uuuh, i don't know. If you compare it to your picture, yes, mine is a bit darker green.
I would indeed dial down the gyro to 10-30% depending on your preference.So I drove it for 10 minutes, it is twitchy as Fπ¢K. I use a Radiolink RC4GS V3 and a R7FG receiver. The gyro is set at 50%, could that be the problem?
The tyres are stock btw.
I read the Radiolink manual so many times. I didn't understand like 50% of it, maybe even more..
Any advice is MUCH appreciated.
Thanks, that is exactly what Gemini told me to change. Dial down the gyro and change the exponantial stuff in the middle.I would indeed dial down the gyro to 10-30% depending on your preference.
Personally I find the Radiolink radio's to be rather twitchy to start with, but I am used/spoiled with a Noble NB4.
I don't know the program-ability of the radiolink by heart, but giving it less dual rate (especially in the center) will help a lot. You'd want the servo to react quickly at the extreme's but in the middle is should be slower and more accurate.
