Charging Error! Check main port.
Fireblade
England
I'm getting the fairly regularly charging my lads 3S lipos up for his MT10, sometimes wiggly bloody everything will shut it up but not always. I understand it's the main battery lead that the error is referring to (deans/T) but when I get the multimeter on it and wiggle cables about and stuff I can never get it to break connection.
I don't get this with my packs and XT90 plugs, should I be swapping over to XT60 for the msall stuff? Do deans plugs suck?
Likely they have been used in combination with systems without anti-spark protection. Deans certainly have none and will have spark damage and corrosion inside the connector.
xt60 also doesn't have anti-spark options, but being round(more surface/clamping) will likely hold much longer than deans
so it's going to be the battery plug internally and putting a new one on will fix it?
