iGlenn
Has anyone got this function working?
According to the manual:
How to change the Travel Adjustment Settings (EPA) on your Varioprop S2R transmitter:
The EPA supports precise and individual endpoint adjustment in each direction for the steering and throttle channels.
- Hold the throttle trigger in the full brake position while powering on the transmitter
- The red LED flashes rapidly, indicating the programming mode is active.
- Throttle End Point adjustment: Hold the trigger in the full throttle position and increase or reduce the travel with the TH Trim button.
- Brake End Point adjustment: Hold the trigger in the full brake position and increase or reduce the travel with the TH Trim button.
- Left Steering End Point adjustment: Hold the steering wheel in the full left position and increase or reduce the travel with the ST Trim button.
- Right Steering End Point adjustment: Hold the steering wheel in the full right position and increase or reduce the travel with the ST Trim button.
- Power Off the transmitter to save the new EPA settings.
