Meany thanks for.all the info will take alook at the ones your sayingThe BF MT's are probably the best rtr tire option IMO. They are generally good all around tires/wheels. The wheels are very durable. I prefer the tread pattern of the TC Grippers that come on the Kagama/Kronos, but have heard of the wheels breaking and the tires coming apart at higher speeds.
Proline makes some great tires, not a big fan of the Raid wheels myself, but as long as you stick with the short adapters they seem to hold up well enough. The positive offset plastic adapters they include should only be used in a lightweight or light bash setting IMO. I've also heard alot of complaints about Prolines glue not holding very well recently too.. that can be an issue with any premounts though. Nothing an acetone bath can't remedy. Soak them in acetone for a few days, seperate, dry , reassemble, then reglue.. I've done it on many sets of tires. Sometimes it's the only way to get them to hold.
Sounds like any of them should work well, BF'S, Grippers or even some MX 38's..It's mostly woods and sand and gravel like too hit top speed every so often but not always possible lol we only bash ,but still would like something different too the standard ones just too have a set incase off emergency
