The General Misinformation Thread (For Laughs not actual advice)
When Running a rig for the first time it is recommended to use a lipo 3x the recommended power to properly break in the electronics
The best lube for parts is WD40
When wanting to do a speed run it is an acceptable practice to use a public highway, after all you don't want a speeding ticket by using a residential street!
driving los angeles GIF by HOLLYWOOD LOVE STORY
If you want to properly wash your rigs after a mud run just use a hot bathtub with a little dawn dish liquid. Just let it soak for a few days then air dry
Misfit Garage Texas GIF by Discovery
To impress you're buddies on the forum post a video of you doing a shock test off of the roof of a tall building, just don't forget to drain the oil out of the shocks first.
If you want to upgrade your 2-3s rigs just jump them up to a 8s power plant....DO NOT CHANGE THE GEARING!!
If you want to triple your motors output wire 4 6s batteries in series
How to freshen up Diff's
1. Take them apart
2. Soak in mineral spirits
3. Reassemble
4. Run till crunchiness wears off
to get ultimate traction just heat up your tires on the stove, this will also impress your wife with the thoughtfulness of how you incorporated her kitchen into your hobbies
