I don't blame ya. It'll doEnded up ordering a firma blx150 esc and the corally motor from jennys.. 2 reasons. I am impatiant and i not going to fight every to try and be first to order a corally esc.
Well crap. Maybe jennys can take it off my orderThe Firma 150A ESC has known issues with failures and catching fire. Here's a link to reviews on Amazon that contains pics of burned out ESCs:
https://www.amazon.com/Spektrum-Fir...show_all_btm?ie=UTF8&reviewerType=all_reviews
You can find more info about failures and fires on the Arrma forum (www.arrmaforum.com).
As long as it hasn't shipped yet. Don't delay though cuz Jenny's is usually pretty quick in my experience. I didn't say anything cuz you said you already ordered.. I will say the HPI esc would be MY choice over the Spektrum given the issues @morrjr71 linked.Well crap. Maybe jennys can take it off my order
Was also gonna mention the soldering aspect. The firma has the ic5 which is great if that's what you use. But the motor(TC) uses 6.5mm bullet connectors, the firma has 4mm bullet connectors.. you can buy adapters, but not thats not the best method. Adapters means you'll definitely have spare wire that'll need to be dealt with. I know soldering can be a daunting task, but in this hobby, it's a priceless skill to have. Plenty of videos and such online if you're not already versed in soldering.I chose the firma for the ease of dropping it in and not having to solder on new connectors.
Thanks, i have ec5 connectors at home to make up new leads. Just nice if i didnt have too. I am a welder for a living so soldering is easy peasy. Only thing i would need help with, is how to make a double battery lead , not sure if you run the positive leads in series or the negative. Thinking about getting a new hobbywing bl150 quicrun.Was also gonna mention the soldering aspect. The firma has the ic5 which is great if that's what you use. But the motor(TC) uses 6.5mm bullet connectors, the firma has 4mm bullet connectors.. you can buy adapters, but not thats not the best method. Adapters means you'll definitely have spare wire that'll need to be dealt with. I know soldering can be a daunting task, but in this hobby, it's a priceless skill to have. Plenty of videos and such online if you're not already versed in soldering.
Just my opinions. Hit us up if you need any help![]()
Well..in that case, I've got this plow frame I need some welding on..Thanks, i have ec5 connectors at home to make up new leads. Just nice if i didnt have too. I am a welder for a living so soldering is easy peasy. Only thing i would need help with, is how to make a double battery lead , not sure if you run the positive leads in series or the negative. Thinking about getting a new hobbywing bl150 quicrun.
| ORI65129 |
| Datenblatt (PDF) | ||
| Facebook teilen |
Ooh.. the GOOD stuff!! I would sure like to give one a test drive!!Homepage / Elektronische Fahrtenregler / Wettbewerb / 1/8 /Vortex R8 Pro X Brushless Regler (220A, 2-6S)
6von7
ORI65129
TEAM ORION Vortex R8 Pro X Brushless Regler (220A, 2-6S)
Datenblatt (PDF) Facebook teilen
There is a BLX185 and 2050kv for $100 on Arrma forum : https://www.arrmaforum.com/threads/arrma-blx-185-esc-and-motor-combo.52170/Ended up ordering a firma blx150 esc and the corally motor from jennys.. 2 reasons. I am impatiant and i not going to fight every one to try and be first to order a corally esc.
That's a great deal..for sure.There is a BLX185 and 2050kv for $100 on Arrma forum : https://www.arrmaforum.com/threads/arrma-blx-185-esc-and-motor-combo.52170/
I swaped an easy run 150 fir the torox out of my radix6 into my kronos. Easy to notice the power difference. I was suprised.I do have my doubts as to whether the claimed specs by TC are accurate too..but the factory programming in the Torox puts my doubts to rest after seeing how well the Torox actually performs. The punch of this system is truly remarkable IMO.
