cool, thx for the pointers!Not mine, maybe just needs a little tightening? Check the bladder maybe its not seated well or dried out and cracked
Hmm Hit up TC, in the meantime you could use a little teflon tape on the bleeder screwOne of mine leaks out the bleeder hole a little. Removed cap, made sure bladder was seated, still same.
Eh, I will mess with it. Ordered a few extra Kronos shocks from JRC, so threw on a new one. Have not messed with the one I took off yet, but I will.Hmm Hit up TC, in the meantime you could use a little teflon tape on the bleeder screw
They fit just the same?Eh, I will mess with it. Ordered a few extra Kronos shocks from JRC, so threw on a new one. Have not messed with the one I took off yet, but I will.
Yes. Same shocks, just a stiffer spring.They fit just the same?
Same on mine that leaked. Means it is not sealing around the bladder when fully tight.Last night I took the shock off. The oil is squirting out the little bleeder hole. Is that normal? It seems to me lessening though.
What did you do to fix it? My black cap is tight against the silver body.Same on mine that leaked. Means it is not sealing around the bladder when fully tight.
Nothing yet. I would say clean the bladder, make sure no issues, and hit the end of the shock cap with a fine grit paper to make sure it is smooth and no burrs. Ordered a few extra Kronos shocks from JRC, so threw on a new one. Have not messed with the one I took off yet, but I will.What did you do to fix it? My black cap is tight against the silver body.
where they C-00173 or C-00172 ?Nothing yet. I would say clean the bladder, make sure no issues, and hit the end of the shock cap with a fine grit paper to make sure it is smooth and no burrs. Ordered a few extra Kronos shocks from JRC, so threw on a new one. Have not messed with the one I took off yet, but I will.
