Kronos Kuron fitted on esc arrma spektrum
Opua
Hi everyone, have any of you mounted the Team Corally Kuron 2050kV motor on the stock Arrma Spektrum esc? I'd like to try mounting it on my Kraton, as I said, while keeping the original esc.
thank you!
It will work but they have different size bullet connectors I think so might need to change them
I’ve done it on a different car. Yup, you’ll need to change the bullets - Kuron is 6.5mm, Spektrum is 4mm.
Yes i have bullet connectors, but do you have noticed some differences between the two motors?
No i have not. They have similar specs.
The Spektrum motors do not have cooling ribs, though. It needs a heat sink for cooling fans. The Kuron does not.
