Kagama Kagama motor and ESC size question
if the chassis layout is similar to the Shogun/Muraco, then yes it will fit. You'll need to trim the screw mount on the side guard that goes underneath the motor or just remove the screw and collar spacer altogether. I tried running a 4985 on 4S, but the costs outweighed the benefits. Weight and punch were the issues. If you plan on running 6-8S it might make it worth it, but those weren't options for me.
As for the Max6, it fits, but you'd also need to trim the rear corner of the side guard to allow for a good fit.
Hope this helps.
