Sketer Hot servo mount
AnthonyJaques
I found that the way they have the servo mount inside that sleeve allows it to overheat with alot of turning it is part of the receiver box not beuno I want to put an open aluminum mount so I may need a bit of dremel work anyone else have this issue second servo for me put a 35 kg in there and it got hot enough to effect the way it works slowed way down the stock one started turning on its own any ideas on upgraded servo mounts
I haven't encountered any issues yet. Could you provide a video of what happens? That might make it easier for people on this forum (who are much smarter and more knowledgeable than me, lol) to help you out with your question. Best of luck!
Did you set your end points? Pretty critical. Also make sure there’s no binding in the steering by disconnecting the drag link and turning the wheels back and forth freely.
