I’ve been eyeing those, what’s held me back thus far is tariffs.. I’ll have to check out the amazon store. Tomorrow is day one of prime days, see if I find any good deals.XC-ESC (OEM of the Mad Max ESCs) are better than Hobbywing IMO (less expensive and they also run cooler) and now that XC-ESC has an Amazon store you can buy them direct with free shipping.
I just checked and most if not all of their ESCs on the Amazon store are 20% off right now. XC E8 was $103 and XC E6 was $127. E6 can be difficult to fit in some Corally vehicles though for example it will only fit in the Shiroi by turning it sideways and removing the switch holder from the sideguard (not that the switch would fit in that it's half the size of a HW switch)I’ve been eyeing those, what’s held me back thus far is tariffs.. I’ll have to check out the amazon store. Tomorrow is day one of prime days, see if I find any good deals.
I’ve been dying to try 12s in my K8. The XC esc’s are very tempting indeed.I just checked and most if not all of their ESCs on the Amazon store are 20% off right now. XC E8 was $103 and XC E6 was $127. E6 can be difficult to fit in some Corally vehicles though for example it will only fit in the Shiroi by turning it sideways and removing the switch holder from the sideguard (not that the switch would fit in that it's half the size of a HW switch)
I think the reason they run cooler than HW may simply be due to the larger heatsink and 40mm fan.
What type of sensor plug does the XC system use? HW compatible?I just checked and most if not all of their ESCs on the Amazon store are 20% off right now. XC E8 was $103 and XC E6 was $127. E6 can be difficult to fit in some Corally vehicles though for example it will only fit in the Shiroi by turning it sideways and removing the switch holder from the sideguard (not that the switch would fit in that it's half the size of a HW switch)
Yes HW compatible and they also provide an adapter for "standard" motor sensor connectors. However the sensor lead coming out of the ESC is a lot shorter than the one on Hobbywing ESCs so you might need an extension cable. It does make it more convenient to run it sensorless but if you're going to do that might as well just get one of the much cheaper XC C series sensorless ESCs.What type of sensor plug does the XC system use? HW compatible?
Thanks! I see XC is closely mimicking HW lineup, especially the 1/8 6s, the motors all look identical, same sizes and specs too.. suspicious. Are they just a rebrand?Yes HW compatible and they also provide an adapter for "standard" motor sensor connectors. However the sensor lead coming out of the ESC is a lot shorter than the one on Hobbywing ESCs so you might need an extension cable. It does make it more convenient to run it sensorless but if you're going to do that might as well just get one of the much cheaper XC C series sensorless ESCs.
No for the ESCs at least, they have similar but different functions in the setup app. Also the XC ESCs have an X-bus lead in addition to the throttle lead which Hobbywing ESCs don't have.The motors could be sourced from the same OEM as Hobbywing's (I am 99% sure HW does not manufacture their motors in-house) but that's not unusual.Thanks! I see XC is closely mimicking HW lineup, especially the 1/8 6s, the motors all look identical, same sizes and specs too.. suspicious. Are they just a rebrand?
They are compatible and work with HW sensored motors in sensor mode but they can't read the temp from a HW motor, but neither can any other sensored ESC except for HW. Hobbywing has intentionally made their motor's temperature sensors incompatible with other manufacturers so this is really HW's marketing buls**t and not anyone else's fault.They are 100% compatible with HW sensored motors. I got a positive reply from their company staff.
Looks good, and at attractive price points too. But HW really has the market cornered in this area, I myself have an entire fleet of RC's running on HW hardware to great effect.
