Muraco Difference between punisher and muraco
Opua
Hi, can anyone explain to me the difference between muraco and punisher? A friend of mine has a punisher, out of the box it was unmanageable as too nervous it was always spinning so it was hard to drive! He changed the oil in the center differential (smoother) he changed the tires putting arrma outcast 4s (the stock tires are very heavy) this way the model is more manageable. So now I'm interested in getting a Muraco but looking at the parts list it looks like the same model as the Punisher....wouldn't get the same model, don't want to change the oil etc... Maybe I'm doing it wrong? What are the differences between the two models except the wheels? Also, is it true that the production model reaches 65 km/h? I've seen videos, some say 54km/h, others over 65km/h... What is the truth?
Wheels, body, hubs and axle stubs, I think that's about it, but regardless you'll always find yourself pulling the diffs to tune it to your liking, plus most manufacturers never fill them all the way up anyway so it's always smart to check
I opened all the diffs on my Muraco after just one short test run, and I found out they were all low on diff fluid. I decided to drain and refill the front and rear diffs: I went with 10 in the rear, and 20 in the front. I kept 100 in the center diff but I filled it up to the proper level. The performance with the new diff fluid was much better than it was out of the box.
