Sketer Bolt on sketer tires
Caleb90
So i installed a 16t pinion, zero chance of a backflip on 3s Hard to get 1 on 4s. What are direct bolt on tires that are larger than stock, that fit with out changing the hubs and arms?
I have the Proline Badlands. They're a bit taller than the stock and give better air/rotation control.
Couple runs ago i noticed the front tires were unloading alot. Had a hard time pulling the front end. I had put 100k in the center diff when i bought it.. so i tore it down and put 300k in, better than before.. but now that its warm out, my motor esc and batteries are getting to hot with 16t pinion. I backed it down to a 14t but havnt run yet
Fan on the motor? Sketer needs that. I run 14t as well. But i have the Kuron 825 system in it. Only run 4s
I have 325 center diff. One fan in the slot behind motor and one fan on top of motor with 15th.
I’ve hit thermal shut down both times I took it out.
I started getting cogging aswell. Thinking 16t was to much
You running that on the stock esc? I ask because i am getting ready to tear my electronics out of my kronos xtr, and selling it off as parts. Putting the motor and esc in the skeeter has crossed my mind
