Trucking in space
So, my first couple months of ownership of my first roller build were a bit rocky.
Some bad gear choices, some rookie mistakes, and some plain bad luck mixed with less than thorough pre-drive checking.
I now know Tekno makes the best pinions (as y'all told me at the beginning).
And one million weight diff fluid in the center works fine (in winter at least)
I had geared down to 11t pinion immediately upon running 6s. My motor is cool as a cucumber (40mm server fan) but the ESC was very toasty.
Well, this afternoon I found the cause. At some point (at least a month ago) I had removed the ESC fan guard to clean it, because it kept stopping. Well, I had not been careful with the wire for the fan (as it's a Hobbywing Gen 2 with the frameless fan that mounts directly to the heatsink, instead of on top of the heatsink) I finally saw today that the stoppage of the fan was because the black wire has been nearly sheared in half. I had been doing small 2 foot jumps at low speeds but my ESC got to 232 degrees, and for some reason didn't shut off (I have thermal cut set to 212 degreess. It smelled a little hot and I saw the fan wasn't spinning, and in the sun I saw the bare spot in the black lead.
I'm okay at soldering but there's like 2mm of wire to work with, so I may have to get creative.
Thanks everyone for all the help getting me to where I am.
And where I am is a truck that I can drive confidently on 6s without overheating or damaging anything.
I don't "bash" super hard, but I got this truck because it's fairly bulletproof for casual off-roading.
I also got a big boost in confidence regarding my AGF servo's steel gears and durability.
I hit a fire hydrant so hard that my steering linkage shed a screw, ripped the threads out, but the servo (even with fully tightened saver) took it like a champ.
I'm not about owning the most expensive stuff, and I couldn't look at myself in the mirror if I paid over $100 for a servo, but if anyone is buying a new servo and wants a durable brand, get an AGF with steel gears. I couldn't be happier with my servo, and with what I paid for my last 3 budget servos, I coulda saved time and hassle and got an AGF to begin with.
Happy holidays everyone.
