Asuga Asuga a-arms question.
CatEatingTroll
Washington not DC
  1. Punisher
I have Asuga a-arms on my truck. The rear ones have mounts for mud guards. On the Corally site I don't see the guards that mount to them. What mud guards fit the rear Asuga a-arms? Do the 6s Kagama guards have the same mounting bolt pattern as the Agusa?
Think fireblade/ toon it hoon it only ones available for Asuga, he also does inserts for the arms
https://ebay.io/m/tIh8nP
Thanks for the input. I went with the Kagama mud guards. The carbon ones didn't have the coverage I'm looking for. My climate is similar to the UK. Really wet.
Kagama won’t fit Asuga too wide & different mounting holes you’ll have to cut & drill them to fit. Might as well make set yourself if gonna do that have saw people make them out of plastic containers etc.
A Kagama 6s mud flap bolted to a Asuga a-arm. No modification necessary.
My rig with Asuga arms I run the vp pro 1107g tires they have like a 1/2” offset y they might give you clearance, with wide hubs also it’s as wide as my truggy with wide arms but it’s on smaller truggy wheels.
